<sys/types.h>
An application source file that includes <sys/types.h> makes the definitions of _LP64 and _ILP32 available through inclusion of <sys/isa_defs.h>. This header also contains a number of basic derived types that should be used whenever appropriate. In particular, the following are of special interest:
clock_t
The type clock_t represents the system times in clock ticks.
dev_t
The type dev_t is used for device numbers.
off_t
The type off_t is used for file sizes and offsets.
ptrdiff_t
The type ptrdiff_t is the signed integral type for the result of subtracting two pointers.
size_t
The type size_t is for the size, in bytes, of objects in memory.
ssize_t
The type ssize_t is used by functions that return a count of bytes or an error indication.
time_t
The type time_t is used for time in seconds.
All of these types remain 32-bit quantities in the ILP32 compilation environment and grow to 64-bit quantities in the LP64 compilation environment.
The use of some of these types is explained in more detail later in this chapter under "Guidelines for Converting to LP64".
