A common technique for distributing and managing applications is to place related applications and libraries into a simple directory hierarchy. Typically, the libraries used by the applications reside in a lib subdirectory, while the applications themselves reside in a bin subdirectory of a base directory. This base directory can then be exported using NFS, and mounted on client machines. In some environments, the automounter and the name service can be used to distribute the applications, and to ensure the filesystem namespace of the application hierarchy is the same on all clients. In such environments, the applications can be built using the -R flag to the linker to specify the absolute pathnames of the directories that should be searched for shared libraries at runtime.
However, in other environments, the file system namespace is not so well controlled, and developers have resorted to using a debugging tool -- the LD_LIBRARY_PATH environment variable -- to specify the library search path in a wrapper script. This is no longer necessary, since the $ORIGIN keyword can be used in pathnames specified to the linker -R option. The $ORIGIN keyword is expanded at runtime to be the name of the directory where the executable itself is located. This effectively means that the pathname to the library directory can be specified using pathname relative to $ORIGIN. This allows the application base directory to be relocated without having to set LD_LIBRARY_PATH at all.
This functionality is available for both 32-bit and 64-bit applications, and it is well worth considering when creating new applications to reduce the dependencies on users or scripts correctly configuring LD_LIBRARY_PATH.
See the Linker and Libraries Guide for further details.
