Solaris 7 64-bit Developer's Guide
Placement of Libraries and Programs
The placement of new libraries and programs follows the standard conventions already described in this book. The 32-bit libraries continue to be located in the same place, while the 64-bit libraries should be placed in the specific architecture-dependent directory under the normal default directories. Placement of 32-bit and 64-bit specific applications should be transparent to the user.
For SPARC machines, this means that 32-bit libraries should be placed in the same library directories. 64-bit libraries should be placed in the sparcv9 subdirectory under the appropriate lib directory. The placement of 32-bit libraries on x86 machines is similar to that for SPARC machines.
Programs that require versions specific to 32-bit or 64-bit environments are a slightly different case. These should be placed in the appropriate sparcv7 or sparcv9 subdirectory of the directory where they are normally located. See "Application Naming Conventions".
