Solaris 7 Maintenance Update 1 Release Notes (SPARC Platform Edition)
install_mu Does Not Function Correctly When Starting It Using sh 4108278
Because of problems regarding the interactions between sh(1) and ksh(1), the install_mu utility may fail to install certain patches correctly whenever you start it using the following command from the command line or from an administrative script:
# /bin/sh ./install_mu arguments
Workaround: Execute install_mu from the command line or from an administrative script as follows:
# ./install_mu arguments
