Solaris 7 5/99 Release Notes (SPARC Platform Edition)
ab2cd -s Does Not Add Locally-Installed Document Collections to the Server (4208243)
When running the AnswerBook2 server from the CD, the command ab2cd -s causes any locally-installed document collections to be added to the server database. However, it does not find any local document collections.
Workaround: If you have locally-installed document collections, install the AnswerBook2 server software. Do not run the server from the CD.
