Some MU2 patches are not automatically installed on systems running the Solaris 7 operating environment. The patch set that is included in the MU2 is complete only for systems running the Solaris 7 3/99 operating environment. If you want to apply MU2 patches to systems running the Solaris 7 operating environment, you will need to apply additional patches.
To determine if these additional patches should be applied to your system, check the /etc/release file for the release date by typing:
# cat /export/root/client_name/etc/release |
If your screen displays this version of the Solaris operating environment, you must apply special patches.
Solaris 7 s998_21al2b SPARC
Copyright 1998 Sun Microsystems, Inc. All Rights Reserved.
Assembled 06 October 1998
| Date | Version of Operating Environment | Perform the following Task: |
| October 1998 | Solaris 7 | Apply additional set of patches in the Special Patch directory |
| January 1999 | Solaris 7 3/99 | Do not apply additional patches in the Special Patch directory |
Change directory to the special patch directory by typing:
From a local copy of the MU2 image, type:
# cd local_directory/Solaris_7_MU2/platform/Patches/special_patches |
From the MU2 CD, type:
# cd /cdrom/Solaris_7_MU2/platform/Patches/special_patches |
where platform is either sparc or i386.
Install the special patches using the following command accordingly:
For each client root area:
# patchadd -R /export/root/client_root -M . patchlist |
For the service area:
# patchadd -S Solaris_2.7 -M . patchlist |
The patches contained in the Special Patch directory for the SPARC platform of the MU2 include:
| 107612-01 | SunOS 5.7 | koi8-R -ow hung before dtlogin screen |
| 107616-01 | SunOS 5.7 | European locale updates |
| 107693-01 | SunOS 5.7 | l10n_euro message updates for SUNW* is SUNW*os 599 |
| 107707-01 | SunOS 5.7 | WOS Message Updates |
The patches contained in the Special Patch directory for the x86 platform of the MU2 include:
| 107613-01 | SunOS 5.7_x86 | koi8-R -cde and ow hung before dtlogin screen |
| 107617-01 | SunOS 5.7_x86 | European locale updates |
| 107694-01 | SunOS 5.7_x86 | l10n_euro message updates for SUNW*is SUNW*os 599 |
| 107708-01 | SunOS 5.7_x86 | WOS Message Updates |
Return to Step 6 in "Installing With install_mu" to complete the installation.
