If you are running a SPARCengineTM UltraTM AX system and you are upgrading from the Solaris 2.5.1 Hardware: 11/97 operating environment with Disk Space Reallocation, the SMEvplu.u package does not install properly.
The following message appears in the upgrade_log:
Doing pkgadd of SMEvplu.u to /. pkgadd: ERROR: SMEvplu is already installed at /usr. Admin file will force a duplicate installation at /. Installation of <SMEvplu> was suspended (administration). No changes were made to the system. pkgadd return code = 4 |
Workaround: Before rebooting, manually remove the exisisting SMEvplu package and install the new SMEvplu.u package.
