Check each NIS map that you will be transferring data from.
Make sure that there are no spurious or incorrect entries. Make sure that the right data is in the correct place and format properly. Remove any outdated, invalid, or corrupt entries. You should also remove any incomplete or partial entries. (It is easier to add incomplete entries after setup than to try transferring incomplete or damages entries from the map.)
Log in to an NIS+ client.
You can perform this task from any NIS+ client--so long as that client belongs to the same domain as the tables into which you want to transfer the information. The examples in this task use the root master server. Since the administrator in these examples is logged in as superuser, the NIS+ principal actually performing this operation (and therefore needing the proper credentials and access rights) is the root master server.
Add /usr/lib/nis to the search path for this shell.
Because you will be using the /usr/lib/nis/nisaddent command once for each table, adding its prefix to the search path will save you the trouble of typing it each time. Here are two examples, one for C shell users and one for Bourne or Korn shell users:
For C Shell
rootmaster# setenv PATH $PATH:/usr/lib/nis |
For Bourne or Korn Shell
rootmaster# PATH=$PATH:/usr/lib/nis rootmaster# export PATH |
Use nisaddent to transfer any of these maps, one at a time:
aliases, bootparams, ethers, group, hosts, netgroup, netmasks, networks, passwd, protocols, rpc, services.
The -publickey and automounter maps require slightly different procedures; for the publickey file, go to Step 6, and for the automounter files, go to Step 7.
By default, nisaddent appends the file information to the table information. To replace or merge instead, use the -r or -m options:
To replace:
rootmaster# nisaddent -r -y nisdomain table |
To append:
rootmaster# nisaddent -a -y nisdomain table |
To merge:
rootmaster# nisaddent -m -y nisdomain table |
The best option for populating the tables for the first time is the -a option, which is the default. The best option to synchronize the NIS+ tables with NIS maps or /etc files is the -m (merge) option.
The -y (lowercase) option indicates an NIS domain instead of a text file. The nisdomain argument is the name of the NIS domain whose map you are going transfer into the NIS+ table. You don't have to name the actual map; the nisaddent utility automatically selects the NIS map that corresponds to the table argument. Here are some examples:
rootmaster# nisaddent -m -y olddoc hosts rootmaster# nisaddent -m -y olddoc passwd rootmaster# nisaddent -m -y olddoc groups |
The first example transfers the contents of the hosts.byname and hosts.byaddr maps in the olddoc (NIS) domain to the NIS+ hosts table in the root domain (NIS+). The second transfers the NIS maps that store password-related information into the NIS+ passwd table. The third does the same with group-related information. For more information about the nisaddent command, see the tables chapter of Solaris Naming Administration Guide.
Since the domain's cred table already stores some credentials, you need to make sure they are not overwritten by the contents of the publickey map that you transfer into the cred table.
First, dump the publickey map to a file, then open that file with your text editor.
rootmaster# makedbm -u /var/yp/olddoc/publickey.byname /etc/publickey.xfr rootmaster# vi /tmp/publickey.tmp |
Now remove the credentials of the workstation you are logged in to from the publickey map.
For rootmaster, there might be one or lines like the following, all of which should be removed:
unix.rootmaster@doc.com public-key:private-key [alg-type] |
Now you can transfer the contents of the file--not the map--into the cred table. Use nisaddent, with the -a (add) option.
rootmaster# nisaddent -a -f /etc/publickey.xfr -t cred.org_dir Publickey |
Notice that this operation transfers only DES credentials into the cred table. You still need to create their LOCAL credentials to the cred table.
Transfer the automounter information.
Although the nissetup utility creates auto_master and auto_home tables, they are not considered standard NIS+ tables. Therefore, transferring information into them requires a slightly different syntax:
rootmaster# nisaddent -y olddoc -Y auto.master -t auto_master.org_dir key-value rootmaster# nisaddent -y olddoc -Y auto.home -t auto_home.org_dir key-value |
The -m and -y options are still required, as is the NIS domain name (in this instance, olddoc). However, you must precede the name of the NIS map (for example, auto.master) with a -Y (uppercase). Then, as is required when transferring automounter text files, you must use the -t option, which indicates that this is a nonstandard NIS+ table. Its arguments are the name of the NIS+ directory object (auto_master.org_dir) and the type of table (key-value). Be sure to append the org_dir suffixes to the NIS+ table names.
Transfer your updates to your replica servers by running nisping.
Running nisping updates any replica servers with your changes.
master1# nisping domain master1# nisping org_dir.domaincom. master1# nisping groups_dir.domain |
Checkpoint the tables.
This step ensures that all the servers supporting the domain transfer the new information from their .log files to the disk-based copies of the tables. If you just finished setting up the root domain, this step affects only the root master server, since the root domain does not yet have replicas. Use the nisping command with the -C (uppercase) option.
rootmaster# nisping -C org_dir Checkpointing replicas serving directory org_dir.doc.com. : Master server is rootmaster.doc.com. Last update occurred at July 14, 1994 Master server is rootmaster.doc.com. checkpoint succeeded. |
If you do not have enough swap space, the server is unable to checkpoint properly, but it does not notify you. One way to make sure you have sufficient swap space is to use list the contents of a table with the niscat command. If you do not have enough swap space, you will see this error message:
can't list table: Server busy, Try Again. |
Even though it does not seem to, this message indicates that you do not have enough swap space. Increase the swap space and checkpoint the domain again.
