The local files version of the switch file supplied with Solaris 7 release is named nsswitch.files.
# # /etc/nsswitch.files: # # An example file that could be copied over to /etc/nsswitch.conf; it # does not use any naming service. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" transports. passwd: files group: files hosts: files networks: files protocols: files rpc: files ethers: files netmasks: files bootparams: files publickey: files # At present there isn't a 'files' backend for netgroup; the system will # figure it out pretty quickly, and won't use netgroups at all. netgroup: files automount: files aliases: files services: files sendmailvars: files |
