Solaris Naming Setup and Configuration Guide
Specifying a Cache-Only Server
A cache-only server does not maintain any authoritative data; it handles queries and asks the hosts listed in the in.named file for the information needed. In other words, a cache-only server handles the same kind of queries that authoritative name servers perform but it does not maintain any authoritative data itself.
Example 13-3 is a sample boot file for a caching-only server.
Example 13-3 Sample Master Boot File for Caching-only Server
; Sample named.boot file for caching-only name server
; type                  domain                 source file or host
directory /var/named
cache                   .                      named.ca
primary                 0.0.127.in-addr.arpa   named.local
You do not need a special line to designate a server as a cache-only server. What denotes a cache-only server is the absence of any secondary or primary authority lines in the boot file, except as noted below.
A cache-only server requires:
