Solaris Naming Setup and Configuration Guide
How to Replicate FNS Under NIS
After the FNS namespace has been set up on the domain master server, additional slave servers can be added to enhance availability and performance of the servers.
  1. As root, edit the /etc/hosts file on the slave server to add the name and IP addresses of all the other NIS servers.
  2. Change directory to /var/yp on the slave server.
  3. To initialize the slave server as a client, type the following:
    # /usr/sbin/ypinit -c
    The ypinit command prompts you for a list of NIS servers. Enter the name of the local slave you are working on first, then the master server, followed by the other NIS slave servers in your domain in order, from the physically closest to the furthest (in network terms).
    Note -
    You must first configure the new slave server as an NIS client so that it can get the NIS maps from the master for the first time. (See "Setting Up NIS Clients" for details.)
  4. To determine if ypbind is running, type:
    # ps -ef | grep ypbind
    If a listing is displayed, ypbind is running.
  5. If ypbind is running, stop it by typing:
    # /usr/lib/netsvc/yp/ypstop
  6. Type the following to restart ypbind:
    # /usr/lib/netsvc/yp/ypstart
  7. To initialize this machine as a slave, type the following:
    # /usr/sbin/ypinit -s master
    Where master is the machine name of the existing NIS master server.
  8. Stop yp processes on the Slave Server:
  9. Restart yp service:
    Alternatively, you can reboot the slave server and allow daemons to start automatically.
