Now you are ready to create a new slave server, as follows:
As root, edit the /etc/hosts file on the slave server to add the name and IP addresses of all the other NIS servers.
To initialize the slave server as a client, type the following:
# /usr/sbin/ypinit -c |
The ypinit command prompts you for a list of NIS servers. Enter the name of the local slave you are working on first, then the master server, followed by the other NIS slave servers in your domain in order from the physically closest to the furthest (in network terms).
You must first configure the new slave server as an NIS client so that it can get the NIS maps from the master for the first time. (See "Setting Up NIS Clients" for details.)
To determine if ypbind is running, type:
# ps -ef | grep ypbind |
If a listing is displayed, ypbind is running.
If ypbind is running, stop it by typing:
# /usr/lib/netsvc/yp/ypstop |
Type the following to restart ypbind:
# /usr/lib/netsvc/yp/ypstart |
To initialize this machine as a slave, type the following:
# /usr/sbin/ypinit -s master |
Where master is the machine name of the existing NIS master server.
Repeat the procedures described in this section for each machine you want configured as an NIS slave server.
