Solaris Naming Administration Guide
Class, Operator, and Rights Syntax
Access rights, whether specified in an environment variable or a command, are identified with three types of arguments: class, operator, and right.
Table 10-7 Access Rights Syntax--Class
Class
Description
n
Nobody: all unauthenticated requests
o
The owner of the object or table entry
g
The group owner of the object or table entry
w
World: all authenticated principals
a
All: shorthand for owner, group, and world (this is the default)
Table 10-8 Access Rights Syntax--Operator
Operator
Description
Adds the access rights specified by right
Revokes the access rights specified by right
Explicitly changes the access rights specified by right; in other words, revokes all existing rights and replaces them with the new access rights.
Table 10-9 Access Rights Syntax--Rights
Right
Description
r
Reads the object definition or table entry
m
Modifies the object definition or table entry
c
Creates a table entry or column
d
Destroys a table entry or column
You can combine operations on a single command line by separating each operation from the next with a comma (,).
Table 10-10 Class, Operator, and Rights Syntax--Examples
Operations
Syntax
Add read access rights to the owner class
o+r
Change owner. group, and world classes' access rights to modify only from whatever they were before
a=m
Add read and modify rights to the world and nobody classes
wn+m
Remove all four rights from the group, world, and nobody classes
gwn-rmcd
Add create and destroy rights to the owner class and add read and modify rights to the world and nobody classes
o+cd,wn+rm
