Password aging is a mechanism you can use to force users to periodically change their passwords.
Password aging allows you to:
Force a user to choose a new password the next time the user logs in. (See "Forcing Users to Change Passwords " for details.)
Specify a maximum number of days that a password can be used before it has to be changed. (See "Setting a Password Age Limit " for details.)
Specify a minimum number of days that a password has to be in existence before it can be changed. (See "Setting Minimum Password Life " for details.)
Specify that a warning message be displayed whenever a user logs in a specified number of days before the user's password time limit is reached. (See "Establishing a Warning Period " for details.)
Specify a maximum number of days that an account can be inactive. If that number of days pass without the user logging in to the account, the user's password will be locked. (See "Specifying Maximum Number of Inactive Days" for details.)
Specify an absolute date after which a user's password cannot be used, thus denying the user the ability to log on to the system. (See "Password Privilege Expiration" for details.)
Keep in mind that users who are already logged in when the various maximums or dates are reached are not affected by the above features. They can continue to work as normal.
Password aging limitations and activities are only activated when a user logs in or performs one of the following operations:
login
rlogin
telnet
ftp
These password aging parameters are applied on user-by-user basis. You can have different password aging requirements for different users. (You can also set general default password aging parameters as described in "Managing Password Aging ".)
There are two ways to force a user to change passwords the next time the user logs in:
Force change keeping password aging rules in effect
passwd -f username |
Force change and turn off password aging rules
passwd -x 0 username |
The -max argument to the passwd command sets an age limit for the current password. In other words, it specifies the number of days that a password remains valid. After that number of days, a new password must be chosen by the user. Once the maximum number of days have passed, the next time the user tries to login with the old password a Your password has been expired for too long message is displayed and the user is forced to choose a new password in order to finish logging in to the system.
The max argument uses the following format:
passwd -x max username |
Where:
username is the login ID of the user
max is one of the following values:
Greater than zero. Any number greater than zero sets that number of days before the password must be changed.
Zero (0). A value of zero (0) forces the user to change passwords the next time the user logs in, and it then turns off password aging.
Minus one (-1). A value of minus one (-1) turns off password aging. In other words, entering passwd -x -1 username cancels any previous password aging applied to that user.
For example, to force the user schweik to change passwords every 45 days, you would type the command:
station1% passwd -x 45 schweik |
The min argument to the passwd command specifies the number of days that must pass before a user can change passwords. If a user tries to change passwords before the minimum number of days has passed, a Sorry less than N days since the last change message is displayed.
The min argument uses the following format:
passwd -x max -n min username |
Where:
max is the maximum number of days a password is valid as described in the section above
min is the minimum number of days that must pass before the password can be changed.
For example, to force the user eponine to change passwords every 45 days, and prevent him from changing it for the first 7 days you would type the command:
station1% passwd -x 45 -n 7 eponine |
The following rules apply to the min argument:
You do not have to use a min argument or specify a minimum number of days before a password can be changed.
If you do use the min argument, it must always be used in conjunction with the -max argument. In other words, in order to set a minimum value you must also set a maximum value.
If you set min to be greater than max, the user is unable to change passwords at all. For example, the command passwd -x 7 -n 8 prevents the user from changing passwords. If the user tries to change passwords, the You may not change this password message is displayed. Setting the min value greater than the max value has two effects:
The user is unable to change password. In this case, only someone with administer privileges could change the password. For example, in situations where multiple users share a common group password, setting the min value for that password greater than the max value would prevent any individual user from changing the group password.
The password is only valid for the length of time set by the max value, but the user cannot change it because the min value is greater than the max value. Thus, there is no way for the user to prevent the password from becoming invalid at the expiration of the max time period. In effect, this prevents the user from logging in after the max time period unless an administrator intervenes.
The warn argument to the passwd command specifies the number of days before a password reaches its age limit that users will start to seeing a Your password will expire in N days message (where N is the number of days) when they log in.
For example, if a user's password has a maximum life of 30 days (set with the -max argument) and the warn value is set to 7 days, when the user logs in on the 24th day (one day past the warn value) the warning message Your password will expire in 7 days is displayed. When the user logs in on the 25th day the warning message Your password will expire in 6 days is displayed.
Keep in mind that the warning message is not sent by Email or displayed in a user's console window. It is displayed only when the user logs in. If the user does not log in during this period, no warning message is given.
Keep in mind that the warn value is relative to the max value. In other words, it is figured backwards from the deadline set by the max value. Thus, if the warn value is set to 14 days, the Your password will expire in N days message will begin to be displayed two weeks before the password reaches its age limit and must be changed.
Because the warn value is figured relative to the max value, it only works if a max value is in place. If there is no max value, warn values are meaningless and are ignored by the system.
The warn argument uses the following format:
passwd -x max -w warn username |
Where:
username is the login ID of the user.
max is the maximum number of days a password is valid as described on "Setting a Password Age Limit ".
warn is the number of days before the password reaches its age limit that the warning message will begin to be displayed.
For example, to force the user nilovna to change passwords every 45 days, and display a warning message 5 days before the password reaches its age limit you would type the command:
station1% passwd -x 45 -w 5 nilovna |
The following rules apply to the warn argument:
You do not have to use the warn argument or specify a warning message. If no warn value is set, no warning message is displayed prior to a password reaching its age limit.
If you do use the warn argument, it must always be used in conjunction with the max argument. In other words, in order to set a warning value you must also set a maximum value.
You can also use Solstice AdminSuite to set a warn value for a user's password.
There are two ways to turn off password aging for a given user:
Turn off aging while allowing user to retain current password
passwd -x -1 username |
Force user to change password at next login, and then turn off aging
This sets the max value to either zero or -1 (see "Setting a Password Age Limit " for more information on this value).
For example, to force the user mendez to change passwords the next time he logs in and then turn off password aging you would type the command:
station% passwd -x 0 mendez |
You can also use Solstice AdminSuite to set this parameter for a user's password.
You can also use the nistbladm command to set this value. For example, to turn off password aging for the user otsu and allow her to continue using her current password, you would type:
station1% nistbladm -m `shadow=0:0:-1:0:0:0:0' [name=otsu],passwd.org_dir |
For additional information on using the nistbladm command, see "The nistbladm Command ".
You can set a specific date on which a user's password privileges expires. When a user's password privilege expires, that user can no longer have a valid password at all. In effect, this locks the user out of the system after the given date because after that date the user can no longer log in.
For example, if you specify an expire date of December 31, 1997, for a user named pete, on January 1, 1998 he will not be able to log in under that user ID regardless of what password he uses. After each login attempt he will receive a Login incorrect message.
Expiration of a user's password privilege is not the same as password aging.
Password aging. A password that has not been changed for longer than the aging time limit is sometimes referred to as an expired password. But that password can still be used to log in one more time. As part of that last login process the user is forced to choose a new password.
Expiration of password privilege. When a user's password privilege expires, the user cannot log in at all with any password.) In other words, it is the user's permission to log in to the network that has expired.
Password privilege expiration dates only take effect when the user logs in. If a user is already logged in, the expiration date has no affect until the user logs out or tries to use rlogin or telnet to connect to another machine at which time the user will not be able to log in again. Thus, if you are going to implement password privilege expiration dates, you should require your users to log out at the end of each day's work session.
If you have Solstice AdminSuite tools available, do not use nistbladm to set an expiration date. Use Solstice AdminSuite tools because they are easier to use and provide less chance for error.
To set an expiration date with the nistbladm command:
nistbladm -m `shadow=n:n:n:n:n:n6:n' [name=login],passwd.org_dir |
Where:
login is the user's login ID
n indicates the values in the other fields of the shadow column.
n6 is the date on which the user's password privilege expires. This date is entered as a number of days since January 1, 1970 (see Table 11-2). n6 can be one of the following values:
Minus one (-1). A value of minus one (-1) turns off the expiration feature. If a user's password has already expired, changing this value to -1 restores (un-expires) it. If you do not want to set any expiration date, type -1 in this field.
Greater than zero. A value greater than zero sets the expiration date to that number of days since 1/1/70. If you enter today's date or earlier, you immediately expire the user's password.
For example, to specify an expiration date for the user pete of December 31, 1995 you would type:
station1% nistbladm -m `shadow=n:n:n:n:n:9493:n' [name=pete],passwd.org_dir |
All of the fields must be filled in with valid values.
To turn off or deactivate password privilege expiration, you must use the nistbladm command to place a -1 in this field. For example, to turn off privilege expiration for the user huck, you would type:
station1% nistbladm -m `shadow=n:n:n:n:n:-1:n' [name=huck],passwd.org_dir |
Or you can use the nistbladm command reset the expiration date to some day in the future by entering a new number of days in the n6 field.
You can set a maximum number of days that a user can go without logging in on a given machine. Once that number of days passes without the user logging in, that machine will no longer allow that user to log in. In this situation, the user will receive a Login incorrect message after each login attempt.
This feature is tracked on a machine-by-machine basis, not a network-wide basis. That is, in an NIS+ environment, you specify the number of days a user can go without logging in by placing an entry for that user in the passwd table of the user's home domain. That number applies for that user on all machines on the network.
For example, suppose you specify a maximum inactivity period of 10 days for the user sam. On January 1, sam logs in to both machine-A and machine-B, and then logs off both machines. Four days later on January 4, sam logs in on machine-B and then logs out. Nine days after that on January 13, sam can still log in to machine-B because only 9 days have elapsed since the last time he logged in on that machine, but he can no longer log in to machine-A because thirteen days have passed since his last log in on that machine.
Keep in mind that an inactivity maximum cannot apply to a machine the user has never logged in to. No matter what inactivity maximum has been specified or how long it has been since the user has logged in to some other machine, the user can always log in to a machine that the user has never logged in to before.
Do not set inactivity maximums unless your users are instructed to log out at the end of each workday. The inactivity feature only relates to logins; it does not check for any other type of system use. If a user logs in and then leaves the system up and running at the end of each day, that user will soon pass the inactivity maximum because there has been no login for many days. When that user finally does reboot or log out, he or she won't be able to log in.
If you have Solstice AdminSuite tools available, do not use nistbladm to set an inactivity maximum. Use Solstice AdminSuite tools because they are easier to use and provide less chance for error.
To set a login inactivity maximum, you must use the nistbladm command in the format:
nistbladm -m `shadow=n:n:n:n:n5:n:n' [name=login],passwd.org_dir |
Where:
n5 is the number of days the user is allowed to go between logins. Inactive can be one of the following values:
Minus one (-1). A value of minus one (-1) turns off the inactivity feature. The user can be inactive for any number of days without losing login privileges. This is the default.
Greater than zero. A value greater than zero sets the maximum inactive period to that number of days.
For example, to specify that the user sam must log in at least once every seven days, you would type:
station1% nistbladm -m `shadow=n:n:n:n:n:7:n:n' [name=sam],passwd.org_dir |
To clear an inactivity maximum and allow a user who has been prevented from logging in to log in again, use nistbladm to set the inactivity value to -1.
