The general syntax of the nistbladm command is:
nistbladm -a column="value" \ column="value" \ column="value" \ ... tablename nistbladm -a indexedname |
nistbladm options \ [columspec | columnvalue] \ [tablename | indexedname] |
Where:
Columnspec is a specification defining a column to be created in a table as described in "Specifying Table Columns ".
columnvalue identifies a particular cell value in the table identified by tablename as described in "nistbladm and Column Values ".
Tablename is the name of the table. For example, hosts.org_dir.doc.com.
Indexedname identifies a particular cell value in a certain table as described in "nistbladm and Column Values ". In essence indexedname is the equivalent of columnvalue plus tablename.
Option |
Description |
-a | -A |
Add an entry to an existing NIS+ table. The -a option returns an error if execution of the command would result in overwritting any existing entry. The -A option forces execution of the command even if it results in overwriting an existing entry. (See "Adding Entries to a Table ".) |
-D defaults |
Specify a different set of default properties when creating an object. (See the nistbladm man page for details.) |
-d |
Destroy a table. (See "Deleting a Table ".) |
-c |
Create a table. (See "Creating a New Table ".) |
-r | -R |
Remove one or more entries from an existing NIS+ table. The -r option returns an error if execution of the command would result in removal of more than one entry. The -R option forces execution of the command even if it results in removing multiple entries. (See "Removing Table Entries ".) |
-m |
An obsoleted option for modifying table entries that is still supported for backwards compatibility. The -e and -E options are the preferred method for editing entries. |
-e | -E |
Edit an entry in an existing NIS+ table. The -e option returns an error if execution of the command would affect more than one entry. The -A option forces execution of the command even if it results in changing an existing entry in such a way as to overwrite a different entry. (See "Modifying Table Entries ".) |
