Solaris Naming Administration Guide
Syntax
To display the contents of a table, use:
niscat [-hM] tablename
To display the object properties of a table, use:
niscat -o tablename
niscat -o entry
Table 14-5 niscat Options
Option
Description
-h
Header. Displays a header line above the table entries, listing the name of each column.
-M
Master. Displays only the entries of the table stored on the Master server. This ensures you get the most up-to-date information and should be used only for debugging.
-o
Object. Displays object information about the table, such as column names, properties, and servers.
