If ypbind crashes almost immediately each time it is started, look for a problem in some other part of the system. Check for the presence of the rpcbind daemon by typing:
% ps -ef | grep rpcbind  |
If rpcbind is not present or does not stay up or behaves strangely, consult your RPC documentation.
You may be able to communicate with rpcbind on the problematic client from a machine operating normally. From the functioning machine, type:
% rpcinfo client  |
If rpcbind on the problematic machine is fine, rpcinfo produces the following output:
program version netid address service owner ... 100007 2 udp 0.0.0.0.2.219 ypbind superuser 100007 1 udp 0.0.0.0.2.219 ypbind superuser 100007 1 tcp 0.0.0.0.2.220 ypbind superuser 100007 2 tcp 0.0.0.0.128.4 ypbind superuser 100007 2 ticotsord \000\000\020H ypbind superuser 100007 2 ticots \000\000\020K ypbind superuser ...  |
Your machine will have different addresses. If they are not displayed, ypbind has been unable to register its services. Reboot the machine and run rpcinfo again. If the ypbind processes are there and they change each time you try to restart /usr/lib/netsvc/yp/ypbind, reboot the system, even if the rpcbind daemon is running.
