Solaris Naming Administration Guide
Missing or Incorrect Domain Name
One client has problems, the other clients are operating normally, but ypbind is running on the problem client. The client may have an incorrectly set domain.
On the client, run the domainname command to see which domain name is set.
Client#7 domainname neverland.com
Compare the output with the actual domain name in /var/yp on the NIS master server. The actual NIS domain is shown as a subdirectory in the /var/yp directory.
Client#7 ls /var/yp...
-rwxr-xr-x 1 root Makefile
drwxr-xr-x 2 root binding
drwx------ 2 root doc.com
If the domain name returned by running domainname on a machine is not the same as the server domain name listed as a directory in /var/yp, the domain name specified in the machine's /etc/defaultdomain file is incorrect. Log in as superuser and correct the client's domain name in the machine's /etc/defaultdomain file. This assures that the domain name is correct every time the machine boots. Now reboot the machine.
Note -
The domain name is case-sensitive.
