Solaris Naming Administration Guide
Preexisting /etc/.rootkey File
Symptoms:
Various insufficient permission to and permission denied error messages.
Possible Cause:
An /etc/.rootkey file already existed when you set up or initialized a server or client. This could occur if NIS+ had been previously installed on the machine and the .rootkey file was not erased when NIS+ was removed or the machine returned to using NIS or /etc files.
Diagnosis:
Run ls -l on the /etc directory and nisls -l org_dir and compare the date of the /etc/.rootkey to the date of the cred table. If the /etc/.rootkey date is clearly earlier than that of the cred table, it may be a preexisting file.
Solution:
Run keylogin -r as root on the problem machine and then set up the machine as a client again.
