Solaris Naming Administration Guide
Reverse Domain Data Not Correctly Transferred to Secondary
While zone domain-named data is properly transferred from the zone primary master server to a zone secondary server, the reverse domain data is not being transferred. In other words, the host.rev file on the secondary is not being properly updated from the primary.
Possible causes:
Syntax error in the secondary server's boot file.
Diagnosis and Solution:
Check the secondary server's boot file. Make sure that the primary server's IP address is listed for the reverse zone entries just as it is for the hosts data.
For example, the following boot file is incorrect because the primary server's IP address (129.146.168.119) is missing from the secondary in-addr.arpa record:
; /etc/named.boot file for dnssecondary
directory /var/named
secondary   doc.com   129.146.168.119        dnshosts.bakup
secondary   168.146.129.in-addr.arpa  doc.rev.bakup
This is what the correct file should look like:
secondary   168.146.129.in-addr.arpa   129.146.168.119  doc.rev.bakup
