Solaris Naming Administration Guide
Nothing in Initial Context
Symptom:
When you run fnlist to see what is in the initial context, you see nothing.
Possible Cause:
This is caused by an NIS+ configuration problem. The organization associated with the user and machine running the fn* commands do not have an associated ctx_dir directory.
Diagnosis:
Use the nisls command to see whether there is a ctx_dir directory.
Solution:
If there is no ctx_dir directory, run fncreate -t org/nis+_domain_name/ to create the ctx_dir directory.
