The named.conf file contains statements and comments. Statements end with a semicolon. Some statements can contain a contain a block of statements. Again, each statement in the block is terminated with a semicolon.
The named.conf file supports the following statements:
Table 28-3| acl | defines a named IP address match list used for access control. The address match list designates one or more IP addresses (dotted-decimal notation) or IP prefixes (dotted-decimal notation followed with a slash and the number of bits in the netmask). The named IP address match list must be defined by an acl statement before it can be used elsewhere; no forward references allowed. |
| include | inserts an include file at the point where the include statement is encountered. Use include to break up the configuration into more easily managed chunks. |
| key | specifies a key ID used for authentication and authorization on a particular name server. See the server statement. |
| logging | specifies the information the server logs and the destination of log messages. |
| options | controls global server configuration options and sets default values for other statements. |
| server | sets designated configuration options associated with a remote name server. Selectively applies options on a per-server basis, rather than to all servers |
| zone | defines a zone. Selectively applies options on a per-zone basis, rather than to all zones. |
options {
directory "/var/named";
datasize 2098;
forward only;
forwarders {
99.11.33.44;
recursion no;
transfers-in 10;
transfers-per-ns 2;
allow-transfer {
127.0.1.1/24;
logging {
category queries { default_syslog; };
include "/var/named/abcZones.conf"
// here are the names of the primary files
zone "cities.zn" {
type master;
file "db.cities.zn";
zone "0.0.127.in-addr.arpa." {
type master;
file "db.127.cities.zn";
zone "168.192.in-addr.arpa" {
type master;
file "db.cities.zn.rev";
zone "sales.doc.com" {
type slave;
file "slave/db.sales.doc";
masters {
192.168.1.151;
type slave;
file "slave/db.sales.doc.rev";
masters {
192.168.1.151;
