Solaris Naming Administration Guide
Resource Record Types
The most commonly used types of resource records are listed in Table 28-5. They are usually entered in the order shown in Table 28-5, but that is not a requirement.
Table 28-5 Commonly Used Resource Record Types
Type
Description
SOA
Start of authority
NS
Name server
A
Internet address (name to address)
PTR
Pointer (address to name)
CNAME
Canonical name (nickname)
TXT
Text information
WKS
Well-known services
HINFO
Host information
MX
Mail exchanger
SOA-- Start of Authority
Example 28-2 shows the syntax of a start-of-authority (SOA) resource record.
Example 28-2 SOA Record Format
name class SOA origin person-in-charge ( serial number
	 refresh
 retry
 expire
 ttl)
The Start-Of-Authority record designates the start of a zone. The zone ends at the next SOA record. The SOA record fields are described below.
name
This field indicates the name of the zone. Note that the zone name must end with a trailing dot. For example: doc.com. is correct, while doc.com is wrong.
class
This field is the address class. For example, IN for Internet (the most commonly used class).
SOA
This field is the type of this resource record.
origin
This field is the name of the host where this data file resides. Note that this host name must end in a trailing dot. For example, dnsmaster.doc.com. is correct, but dnsmaster.doc.com is wrong.
person-in-charge
This field is the email address of the person responsible for the name server. For example, kjd.nismaster.doc.com. Again, this name must end with a trailing dot.
serial
This field is the version number of this data file. You must increment this number whenever you make a change to the data: secondary servers use the serial field to detect whether the data file has been changed since the last time they copied the file from the master server.
refresh
This field indicates how often, in seconds, a secondary name server should check with the primary name server to see if an update is needed. For example, 7200 indicates a period of two hours.
retry
This field indicates how long, in seconds, a secondary server is to retry after a failure to check for a refresh.
expire
This field is the upper limit, in seconds, that a secondary name server is to use the data before it expires for lack of getting a refresh.
ttl
This field is the default number of seconds to be used for the time-to-live field on resource records that don't have a ttl specified elsewhere.
There should only be one SOA record per zone. Example 28-3 is a sample SOA resource record.
Example 28-3 Sample SOA Resource Record
;name class 		SOA 	origin				 person-in-charge
doc.com. IN		SOA	dnsmaster.doc.com. root.nismaster.doc.com. (
							101			;Serial
							7200		;Refresh
							3600		;Retry
							432000		;Expire
							86400)		;Minimum			 )
NS--Name Server
Example 28-4 shows the syntax of a name-server (NS) resource record:
Example 28-4 NS Record Format
domainname [optional TTL] class NS name-server-name
The name-server record lists by name a server responsible for a given domain. The name field lists the domain that is serviced by the listed name server. If no name field is listed, then it defaults to the last name listed. One NS record should exist for each primary and secondary master server for the domain. Example 28-5 is a sample NS resource record.
Example 28-5 Sample NS Resource Record
;domainname    [TTL] 	 class	NS	nameserver
doc.com        90000     IN	NS 	sirius.doc.com.
A--Address
Example 28-6 shows the syntax of an address (A) resource record:
Example 28-6 Address Record Format
machinename	[optional TTL] class A	address
The address (A) record lists the address for a given machine. The name field is the host name, and the address is the IP address. One A record should exist for each address of the machine (in other words, routers, or gateways require at least two entries, a separate entry including the IP address assigned to each network interface).
Example 28-7 Sample Address Record
;machinename	[TTL]	class	A	address
sirius		IN		A	123.45.6.1
HINFO--Host Information
Example 28-8 shows the syntax of a host-information (HINFO) resource record:
Example 28-8 HINFO Record Format
[optional name] [optional TTL] 	class	HINFO hardware	OS
The host-information resource record (HINFO) contains host-specific data. It lists the hardware and operating environment that are running at the listed host. If you want to include a space in the machine name or in the entry in the hardware field, you must surround the entry with quotes. The name field specifies the name of the host. If no name is specified, it defaults to the last in.named host. One HINFO record should exist for each host. Example 28-9 is a sample HINFO resource record.
Example 28-9 Sample HINFO Resource Record
;[name]   [TTL] class HINFO   hardware    OS
                IN    HINFO   Sparc-10    UNIX
Caution - Caution -
Because the HINFO field provides information about the machines on your network, many sites consider it a security risk and no longer use it.
WKS--Well-Known Services
Example 28-10 shows the syntax of a well-known services (WKS) resource record:
Example 28-10 WKS Record Format
[Optional name] [TTL] class WKS address protocol-list-of-services
The Well-Known Services (WKS) record describes the well-known services supported by a particular protocol at a specified address. The list of services and port numbers come from the list of services specified in the services database. Only one WKS record should exist per protocol per address. Example 28-11is an example of a WKS resource record.
Example 28-11 Sample WKS Resource Record
;[name]	[TTL]	class	WKS	address 	 protocol-list-of-services
altair		IN	WKS	123.45.6.1	 TCP ( smtp discard rpc
                                                 sftp uucp-path systat daytime
						 netstat qotd nntp doc.com )
Caution - Caution -
The WKS record is optional. For security reasons, most sites no longer provide this information.
CNAME--Canonical Name
Example 28-12 shows the syntax of a canonical-name (CNAME) resource record.
Example 28-12 CNAME Record Format
 nickname [optional TTL] class CNAME	canonical-name
The Canonical-Name Resource record (CNAME) specifies a nickname or alias for a canonical name. A nickname should be unique. All other resource records should be associated with the canonical name and not with the nickname. Do not create a nickname and then use it in other resource records. Nicknames are particularly useful during a transition period, when a machine's name has changed but you want to permit people using the old name to reach the machine. Nicknames can also be used to identify machines that serve some specific purpose such as a mail server. Example 28-13is a sample CNAME resource record.
Example 28-13 Sample CNAME Resource Record
;nickname      [TTL]	class	CNAME	canonical-name
mailhost		IN	CNAME	antares.doc.com
PTR--Pointer Record
Example 28-14 shows the syntax for a pointer (PTR) resource record.
Example 28-14 PTR Record Format
 special-name	[optional TTL]  class	 PTR-real-name
A pointer record allows special names to point to some other location in the domain. In the example, PTR's are used mainly in the in-addr.arpa. records for the translation of an address (the special name) to a real name. When translating an address, if the domain is fully qualified only the machine identification number need be specified. PTR names should be unique to the zone. The PTR records Example 28-15sets up reverse pointers for the special in-addr.arpa domain.
Example 28-15 Sample PTR Resource Record
;special name   [TTL]	class	PTR-real-name
1			IN	PTR sirius.doc.com.
MX--Mail Exchanger
Example 28-16 shows the syntax for a mail-exchanger (MX) resource record.
Example 28-16 MX Record Format
name [optional TTL] class	MX preference-value mailer-exchanger
The mail-exchanger resource records are used to specify a machine that knows how to deliver mail to a domain or specific machines in a domain. There may be more than one MX resource record for a given name. In Example 28-17, Seismo.CSS.GOV. (note the fully qualified domain name) is a mail gateway that knows how to deliver mail to Munnari.OZ.AU. Other machines on the network cannot deliver mail directly to Munnari. Seismo and Munnari may have a private connection or use a different transport medium. The preference-value field indicates the order a mailer should follow when there is more than one way to deliver mail to a single machine. The value 0 (zero) indicates the highest preference. If there is more than one MX resource record for the same name, records may or may not have the same preference value.
You can use names with the wildcard asterisk (*) for mail routing with MX records. There are likely to be servers on the network that simply state that any mail to a domain is to be routed through a relay. In Example 28-17, all mail to hosts in domain foo.com is routed through RELAY.CS.NET. You do this by creating a wildcard resource record, which states that the mail exchanger for *.foo.com is RELAY.CS.NET. The asterisk will match any host or subdomain of foo.com, but it will not match foo.com itself.
Example 28-17 Sample MX Resource Record
;name	 	[TTL]	class		MX	 preference mailer-exchanger
Munnari.OZ.AU.		IN		MX	 0	Seismo.CSS.GOV.
foo.com.		IN		MX	 10	RELAY.CS.NET.
*.foo.com.		IN		MX	 20	RELAY.CS.NET.
