Solaris Naming Administration Guide
Binding a Reference to a Composite Name
The fnbind command is used to bind an existing reference (name) to a new composite name.
fnbind -r [-s][-v][-L] name [-O|-U] newname reftype addrtype [-c|-x] address
Table 20-4 fnbind Command Options
Option
Description
name
The existing composite name
newname
The composite name of the new binding
addrtype
Address type to use. Applications-specific such as onc_cal_str.
address
Address contents to use. For example, tsvi@altair.
reftype
Reference type to use. Applications-specific such as one_calendar.
-s
Bind to newname even if it is already bound. This replaces the previous binding of newname. Without -s, fnbind fails if newname is already bound.
-v
Display the reference that will be bound to newname.
-L
Create an XFN link using oldname and bind it to newname.
-r
Bind newname to the reference constructed by the command line arguments.
-c
Store address contents in the form as entered, do not use XDR-encoding.
-x
Convert address to a hexadecimal string without converting it to XDR-encoding.
-O
The identifier format is FN_ID_ISO_OID_STRING, an ASN.1 dot-separated integer list string.
-U
The identifier format is FN_ID_DCE_UUID, a DCE UUID in string form.
For example:
To add a calendar binding for the user jamal:
# fnbind -r user/jamal/service/calendar onc_calendar onc_cal_str
 jamal@cygnus
To replace the existing binding of org//service/Sparc-4 with that of org//service/printer:
# fnbind -s org//service/printer org//service/Sparc-4
To copy the reference site/bldg-5/service/printer to user/ando/service/printer:
# fnbind site/bldg-5/service/printer user/ando/service/printer
To bind the reference site/bldg-5/service/printer to user/ando/service/printer using a symbolic link:
# fnbind -L site/bldg-5/service/printer user/ando/service/printer
To bind the name thisens/service/calendar to the address staff@altair, when staff@altair is a reference of the type onc_cal and an address of the type onc_cal_str:
# fnbind -r thisens/service/calendar onc_calendar onc_cal_str staff@altair
To bind newname to the reference constructed by its command line address
# fnbind -r [-sv] newname [-O|-U] reftype {[-O|-U] addrtype [-c|-x] address}
