The fnattr command can be used to add, delete or modify attributes associated with a name. You can make modifications one at a time, or batch several within the same command.
fnattr [-l] name to list attributes for name.
fnattr name -a-s -U -O attrib values to add an attribute
fnattr name -m -O -U attrib oldvalue newvalue to modify an attribute
fnattr name -d -O | -U [values attrib] to destroy an attribute
 Option  |
 Description  |
 name  |
 The composite name  |
 attrib  |
 The identifier of an attribute  |
 values  |
 One or more attribute values  |
 oldvalue  |
 An attribute value to be replaced by a new value  |
 newvalue  |
 The attribute value that replaces an old value  |
 -a  |
 Add an attribute  |
 -d  |
 Destroy an attribute  |
 -l  |
 List attributes  |
 -m  |
 Modify an attribute  |
 -s  |
 Replace all old attribute values with the new values for the attribute specified.  |
 -O  |
 The identifier format is FN_ID_ISO_OID_STRING, an ASN.1 dot-separated integer list string.  |
 -U  |
 The identifier format is FN_ID_DCE_UUID, a DCE UUID in string form.  |
For example:
To show all of the attributes associated with the user name rosa:
# fnattr user/rosa  |
To display the size attribute associated with the user uri:
# fnattr user/uri/ size  |
For a user named devlin, to add an attribute named shoesize with a value of small, delete the hatsize attribute, and change the dresssize attribute value from 12 to 8:
# fnattr user/devlin -a shoesize small -d hatsize -m dresssize 12 8  |
