Use the org type to create an organization context. The composite name must be one of the following depending on the primary naming service:
NIS+. The name of an existing NIS+ domain (or subdomain). An NIS+ domain is an NIS+ directory object with an org_dir subdirectory. Populated host and passwd tables for the domain must exist in the domain's org_dir subdirectory.
NIS. The name of the NIS domain. Associated host and passwd maps must also exist.
/etc files. There is only the org// organization context when using /etc files.
Assume the root NIS+ domain is doc.com and there is a subdomain sales.doc.com. To create a sales organization context to correspond to the sales subdomain, you would enter the following command:
fncreate -t org org/sales/ |
When the new context is created, a ctx_dir directory, if it does not already exist, is created under the directory of the domain, sales.doc.com.
Because this example used only the -t option without the -o option, it created an organization context for the composite name org/sales/ and, in addition, created hostname, username, and service subcontexts for it, which in turn, created host and user contexts, and service subcontexts for hosts and users. In effect, that is the same as running the following commands:
fncreate -t hostname org/sales/host/ fncreate -t username org/sales/user/ fncreate -t service org/sales/service/ |
If, instead, you ran fncreate -o -t orgthe org context is created and the hostname, username, and service contexts are also created, but not populated with host and user contexts.
The org context is owned by the administrator who executed the fncreate command, as are the hostname, username, and service subcontexts. The host and user contexts, however, and their subcontexts are owned by the hosts or users for which the contexts were created. In order for the administrator to subsequently manipulate host and user contexts, the NIS_GROUP environment variable must have been set accordingly at the time fncreate is executed. For example, assuming a C-Shell, to set NIS_GROUP to fns_admins.doc.com:
rootmaster# setenv NIS_GROUP fns_admins.doc.com |
