Solaris Naming Administration Guide
Using cron For Map Transfers
Maps have different rates of change. For instance, some may not change for months at a time, such as protocols.byname among the default maps and auto_master among the nondefault maps; but passwd.byname may change several times a day. Scheduling map transfer using the crontab command allows you to set specific propagation times for individual maps.
To periodically run ypxfr at a rate appropriate for the map, the root crontab file on each slave server should contain the appropriate ypxfr entries. ypxfr contacts the master server and transfers the map only if the copy on the master server is more recent than the local copy.
Note -
If your master server runs rpc.yppasswdd with the default -m option, then each time someone changes their yp password, the passwd daemon runs make, which rebuilds the passwd maps.
