Solaris 7 リリースで提供される NIS+ 用スイッチファイルは、nsswitch.nisplus です。
# # /etc/nsswitch.nisplus: # # An example file that could be copied over to /etc/nsswitch.conf; it # uses NIS+ (NIS Version 3) in conjunction with files. # # "hosts:" and "services:" in this file are used only if the # /etc/netconfig file has a "-" for nametoaddr_libs of "inet" transports. # the following two lines obviate the "+" entry in /etc/passwd and /etc/group. passwd: files nisplus group: files nisplus # consult /etc "files" only if nisplus is down. hosts: nisplus [NOTFOUND=return] files #Uncomment the following line, and comment out the above, to use both DNS #and NIS+. You must also set up the /etc/resolv.conf file for DNS name #server lookup. See resolv.conf(4). #hosts: nisplus dns [NOTFOUND=return] files services: nisplus [NOTFOUND=return] files networks: nisplus [NOTFOUND=return] files protocols: nisplus [NOTFOUND=return] files rpc: nisplus [NOTFOUND=return] files ethers: nisplus [NOTFOUND=return] files netmasks: nisplus [NOTFOUND=return] files bootparams: nisplus [NOTFOUND=return] files publickey: nisplus netgroup: nisplus automount: files nisplus aliases: files nisplus sendmailvars: files nisplus |
