Use the coreadm command without any options to display the current core dump configuration.
$ coreadm
               global core file pattern: /var/core/core.%f.%p
                 init core file pattern: core
                      global core dumps: enabled
                 per-process core dumps: enabled
                global setid core dumps: enabled
           per-process setid core dumps: disabled
               global core dump logging: disabled
