Solaris 7 System Administration Supplement
How to Disable an Auxiliary (Remote) Console
  1. Log in to the system as superuser.
  2. Select one of the following steps:
    1. Disable the auxiliary console.
      # consadm -d devicename
      or
    2. Disable the auxiliary console and remove it from the list of persistent auxiliary consoles.
      # consadm -p -d devicename
  3. Verify that the auxiliary console has been disabled.
    # consadm
Example--Disabling an Auxiliary (Remote) Console
# consadm -d /dev/term/a
# consadm
