If a global core file directory is enabled, core files can be distinguished from one another by using the variables described in the following table.
 Variable Name  |
 Variable Definition  |
 %p  |
 Process ID  |
 %u  |
 Effective user ID  |
 %g  |
 Effective group ID  |
 %f  |
 Executable file name  |
 %n  |
 System node name, equivalent to the uname -n output  |
 %m  |
 Machine name, equivalent to the uname -m output  |
 %t  |
 Decimal value of time(2) system call  |
 Literal %  |
For example, if the global core file path is set to:
/var/core/core.%f.%p
and a sendmail process with PID 12345 terminates abnormally, it produces the following core file:
/var/core/core.sendmail.12345
