Solaris 7 (SPARC Platform Edition) 11/99 Release Notes
sun4m Solstice AutoClients Fail to Mount Cache After an Upgrade From the Solaris 2.6 Hardware: 3/98 Release (4121951)
SolsticeTM AutoClientTM systems display the following message when rebooting:
fsck -F cachefs: Cache directory /.cache/rootcache does not exist.mount -F cachefs: cache fsck mount failedfsck -F cachefs: Cache directory /.cache/rootcache does not exist.mount -F cachefs: cache fsck mount failed
This directive indicates to the kernel that the root file system is of type cachefs. To determine whether or not a specific Solstice AutoClient system can be affected by this problem before you attempt an upgrade, examine the directory /export/root/client-name/var/sadm/pkg on the server (this is the Solstice AutoClient system's /var/sadm/pkg directory). If this directory contains a subdirectory called TADcar, the Solstice AutoClient system may be affected.
Workaround: Edit the /etc/system file for the Solstice AutoClient systems after the upgrade by appending the following line:
rootfs:cachefs
The Solstice AutoClient systems' /etc/system file is stored on the server as /etc/root/client-name/etc/system.
