After you upgrade from the Solaris 2.6 Hardware 3/98 or the Solaris 2.6 5/98 operating environment and if your systems have sun4u diskless clients or Solstice AutoClient systems, then the SUNWcvc.u and SUNWdrr.u packages are not installed on diskless clients or Solstice AutoClient systems.
Workaround: After you have completed an upgrade, add the SUNWcvc.u and SUNWdrr.u packages to a sun4u diskless client or Solstice AutoClient system as follows with a client called foo:
Mount the Solaris 7 11/99 CD for the SPARC platform.
Change to the following directory:
# cd /cdrom/sol_7_1199_sparc/s0/Solaris_2.7/Product |
Add the following packages using the pkgadd command:
# pkgadd -R /export/root/foo -d `pwd` SUNWcvc.u # pkgadd -R /export/root/foo -d `pwd` SUNWdrr.u |
