Solaris 7 (SPARC Platform Edition) 11/99 Release Notes
Installing SUNWab2u Before SUNWab2r and SUNWab2s Causes Problems (4230969)
Installing the SUNWab2u package before the other AnswerBook2 packages, SUNWab2r and SUNWab2s, causes the following:
Workaround: Use the installer (Web Start utility) or the pkgrm command to remove the SUNWab2u, SUNWab2r, and SUNWab2s packages.
To install the packages in the correct order, use the installer (Web Start utility).
If you install the packages manually using the pkgadd command, install them in the following order:
  1. SUNWab2r
  2. SUNWab2s
  3. SUNWab2u
