Solaris 7 (SPARC Platform Edition) 11/99 Release Notes
Web Start Installer for Solaris 7 11/99 Does Not Install the Netscape Communicator CD Included With Solaris 7 8/99 (4274778)
The Web Start installer in the Solaris 7 11/99 release does not install Netscape from the NetscapeTM Communicator CD included with the Solaris 7 8/99 release. The Web Start installer will prompt you with the following message:
Insert the CD-ROM labeled 'Netscape Communicator 4.51' into the
CD-ROM drive and continue.
The message appears until you insert the Netscape Communicator CD that is included with the Solaris 7 11/99 release or press the Skip button. If you press the Skip button, Netscape Communicator 4.51 is not installed.
Workaround: You may choose one of the following workarounds:
