Solaris 7 (SPARC Platform Edition) 11/99 Release Notes
The SMEvplu.u Package Does Not Install Properly When Upgrading From Solaris 2.5.1 Hardware: 11/97 With Disk Space Reallocation (4190800)
If you are running a SPARCengineTM UltraTM AX system and you are upgrading from the Solaris 2.5.1 Hardware: 11/97 operating environment with Disk Space Reallocation, the SMEvplu.u package does not install properly.
The following message appears in the upgrade_log:
Doing pkgadd of SMEvplu.u to /.
pkgadd: ERROR: SMEvplu is already installed at /usr.
Admin file will force a duplicate installation at /.
Installation of <SMEvplu> was suspended (administration).
No changes were made to the system.
pkgadd return code = 4
Workaround: Before rebooting, manually remove the exisisting SMEvplu package and install the new SMEvplu.u package.
  1. Remove the incomplete SMEvplu package:
    # pkgrm -R /a SMEvplu
  2. Change directories to the Solaris 7 Product directory:
    # cd /cdrom/sol_7_1199_sparc/s0/Solaris_2.7/Product
  3. Add the correct SMEvplu.u package:
    # pkgadd -R /a -d `pwd` SMEvplu.u
