Solaris 7 (SPARC Platform Edition) 11/99 Release Notes
ab2cd Causes TCL Errors When Started With LC_ALL Set to a Value Other Than C or Blank (4249211)
When running the AnswerBook2 server with the command ab2cd, if LC_ALL is set to a value other than C or blank, you will see the following error message:
Internal Server Plugin Error
../dwinterp/dwinterp.cc reported
TCL script exception:
File not found: "/tmp/.ab2/data/config/dynaweb.dwc"
Please notify your System Administrator.../dwsp/dwspns.cc reported "Null
Pointer" exception caught in ../dwsp/dwspns.cc, line 244
Workaround: Before starting ab2cd, type the following command:
# unsetenv LC_ALL
