In the Getting Started with PDASync section of online help, under the heading Setting the Port, Step 2 states, "Select the port (A, B or C) to which you connect the PDA." This information is misleading.
Depending on the hardware features of your machine, PDASync may display different ports when listing the available serial ports to which you connect the PDA. On most machines, /dev/term/a and /dev/term/b are displayed.
