Solaris 7 (Intel Platform Edition) 11/99 Hardware Compatibility List
Video Display Devices
Note -
Video support is limited to a single analog video output, typically from the 15-pin mini D-sub connector on the video device. Other output formats, such as TV or digital output, that are available from some devices are not supported at this time. Multiple analog monitor output is also not supported at this time.
Note -
``--'' in the Bus column indicates that the video device uses either a PCI connector or an AGP connector, or is mounted directly on a motherboard.
Note -
The information in the Video Chip column does not guarantee that video cards made by another manufacturer using the same video device will work. Only the specific models listed by Vendor, Model, Bus, and Video Chip have been tested.
Table 1-26 Video Display Devices
Vendor
Model
Bus
Video Chip
Resolution and Color Depth
800x 600
1024x 768
1152x 900
1280x 1024
1600x 1200
8
24
8
24
8
24
8
24
8
24
3Dlabs
Permedia 2
PCI, AGP
3Dlabs Permedia 2
v
v
v
v
v
v
v
v
v
Acer
ET4000/W32 [The ET4000/W32 video cards that are shipped with Acer machines are not all the same. If you encounter any display problems when the window system is running, try using a different add-on board that is compatible with the Solaris operating environment.]
ISA
Tseng ET4000/W32
v
v
ALR
Flyer
VL
WD90C33
v
AST
Manhattan 5090P [Video adapters based on the Cirrus Logic GD5424 chipset with 512-Kbyte DRAM may not perform well in 800x600x256 mode, particularly if the selected monitor refresh rate is 60 Hz or higher.]
Cirrus Logic GD5424
v
ATI
3D Pro Turbo PC2TV
PCI
ATI 3D RAGE II+
v
v
v
v
v
v
v
v
v
3D RAGE [Sun does not guarantee that every video device with this chip will work, but it is possible that your model can be used successfully. ]
ATI 3D RAGE
v
v
v
v
v
3D RAGE II
ATI 3D RAGE II
v
v
v
v
v
v
v
v
v
3D RAGE II+
ATI 3D RAGE II+
v
v
v
v
v
v
v
v
v
3D Xpression
PCI
ATI 3D RAGE
v
v
v
v
v
3D Xpression+ PC2TV
PCI
ATI 3D RAGE II
v
v
v
v
v
v
v
v
v
8514 Ultra
ISA
ATI Mach8
v
All-in-Wonder
PCI
ATI 3D RAGE II+
v
v
v
v
v
v
v
v
v
Graphics Pro Turbo [Support is provided for ATI cards with ATI Mach64 chips and these RAMDACS: ATT68860, ATT20C408, ATT20C491, ATT20C498, STG1702, and STG1703.]
PCI
ATI Mach64
v
v
v
v
v
v
Graphics Pro Turbo
VLB
ATI Mach64
v
v
v
v
v
v
Graphics Pro Turbo 1600
PCI
ATI Mach64
v
v
v
v
v
v
v
v
v
Graphics Ultra
ISA
ATI Mach8
v
Graphics Ultra+
ISA
ATI Mach32
v
v
Graphics Ultra Pro
ISA
ATI Mach32
v
v
v
v
Graphics Ultra Pro
PCI
ATI Mach32
v
v
v
v
Graphics Ultra Pro
VLB
ATI Mach32
v
v
v
v
Graphics Xpression
PCI
ATI Mach64
v
v
v
v
v
Graphics Xpression
VLB
ATI Mach64
v
v
v
v
v
Mach64
ATI Mach64
v
v
Mach64CT
ATI Mach64CT
v
v
v
v
v
Mach64CT Rev. 2
ATI Mach64CT
v
v
v
v
v
Mach64VT
PCI
ATI Mach64VT
v
v
v
v
v
RAGE IIC
PCI, AGP
ATI RAGE IIC
v
v
v
v
v
v
v
v
v
RAGE PRO TURBO
ATI RAGE PRO TURBO [The ATI RAGE PRO TURBO is the same video chip as the ATI RAGE PRO.]
v
v
v
v
v
v
v
v
v
v
VGA Wonder+
ISA
ATI Mach8
v
VGA Wonder XL
ISA
ATI Mach8
v
VGA Wonder XL 24
ISA
ATI Mach8
v
Video Expression
PCI
ATI Mach64VT
v
v
v
v
v
Winturbo [The ATI Winturbo model is equivalent to the Gateway ATI GX Mach64 PCI video card. ]
PCI
ATI Mach64
v
v
v
v
v
XPERT@Play
PCI, AGP
ATI RAGE PRO TURBO
v
v
v
v
v
v
v
v
v
v
XPERT@Work
PCI, AGP
ATI RAGE PRO TURBO
v
v
v
v
v
v
v
v
v
v
Boca
Voyager 64
PCI
S3 Trio64
v
v
v
v
v
Chips & Technology
65540
F65540
v
v
65545
F65545
v
v
v
65548
F65548
v
v
v
65550
F65550
v
v
v
v
Cirrus Logic
5420 w/512 KB DRAM
Cirrus Logic GD5420
v
5428
Cirrus Logic GD5428
v
v
v
v
5428 w/512 KB VRAM
Cirrus Logic GD5428
v
5429
Cirrus Logic GD5429
v
v
v
v
5430
Cirrus Logic GD5430
v
v
v
v
5434
Cirrus Logic GD5434
v
v
v
v
v
v
5436
Cirrus Logic GD5436
v
v
v
v
v
54M40
Cirrus Logic GD54M40
v
v
v
v
v
5446
Cirrus Logic GD5446
v
v
v
v
v
5465
PCI, AGP
Cirrus Logic GD5465
v
v
v
v
v
v
v
5480
Cirrus Logic GD5480
v
v
v
v
v
v
v
v
v
7543
Cirrus Logic GD7543
v
v
Compaq
Professional Workstation 5000
PCI
MGA-2064W
v
v
v
v
v
v
v
v
v
v
ProLiant
Cirrus Logic GD5420
v
ProLiant 800
Cirrus Logic GD5440
v
ProLiant 1000
Cirrus Logic GD5420
v
ProLiant 1500
Cirrus Logic GD5420
v
ProLiant 2000
Cirrus Logic GD54M30
v
ProLiant 2500
Cirrus Logic GD5420
v
ProLiant 4000
Cirrus Logic GD5420
v
ProLiant 4500
Cirrus Logic GD5424
v
ProLiant 5000
Cirrus Logic GD5424
v
ProLinea
ISA
Tseng ET4000
v
ProSignia [The ProSignia 300 systems and some models of the ProSignia Server systems with the Cirrus Logic 5424 graphics chip are supported. Choose one of the "Cirrus Logic 5424 (512k)" entries when configuring the window system using kdmconfig.]
Cirrus Logic GD5420
v
ProSignia 300
Cirrus Logic GD5424
v
ProSignia 300/500
Cirrus Logic GD5420
v
ProSignia 300/500
Cirrus Logic GD5424
v
QVision 2000
PCI
Matrox MGA-2
v
v
v
v
v
QVision 2000 (Rev. G)
PCI
Matrox MGA-3
v
v
v
v
v
CompuAdd
Hi-Res VGA
ISA
Tseng ET4000
v
DEC
DECpc XL 590
Cirrus Logic GD5428
v
Dell
DE Series
ISA
Tseng ET4000
v
L Series
Tseng ET4000/W32
v
L Series
Tseng ET4000/W32i
v
M/ME Series
S3 805
v
OptiPlex DGX 590
ATI Mach64
v
v
v
v
v
OptiPlex XMT 590
S3 Vision 864
v
v
v
v
v
PowerEdge SP5xx
ATI Mach32
v
Diamond
Fire GL 1000 Pro
AGP
3Dlabs Permedia 2
v
v
v
v
v
v
v
v
v
SpeedStar 24x
ISA
WD90C31
v
SpeedStar 64/
SpeedStar 64 Graphics 2000XL Series
ISA, PCI
Cirrus Logic GD5434
v
v
v
v
v
SpeedStar Plus
ISA
Tseng ET4000
v
SpeedStar Pro/ SpeedStar Pro 1100
ISA
Cirrus Logic GD5426
v
Stealth 3D 2000
PCI
S3 ViRGE (86C325)
v
v
v
v
v
Stealth 3D 2000/Pro
PCI
S3 ViRGE/DX (86C375)
v
v
v
v
v
v
Stealth 3D 3000
PCI
S3 ViRGE/VX (86C988)
v
v
v
v
v
v
v
v
v
Stealth 32
PCI
Tseng ET4000/W32p
v
v
v
v
v
Stealth 32
VLB
Tseng ET4000/W32p
v
v
v
v
v
Stealth 64 DRAM/ Stealth 64 Graphics 2000 Series
PCI, VLB
S3 Vision 864
v
v
v
v
v
Stealth 64 DRAM
PCI
S3 Trio64
v
v
v
v
v
Stealth 64 VRAM
PCI
S3 Vision 964
v
v
v
v
v
v
v
Stealth 64 VRAM
VLB
S3 Vision 964
v
v
v
v
v
v
v
Stealth Video DRAM/ Stealth 64 Video 2000 Series
PCI, VLB
S3 Vision 868
v
v
v
v
v
v
Stealth 64 Video 2001
PCI
S3 Vision 765
v
v
v
v
v
Stealth Video VRAM/ Stealth 64 Video 3000 [For cards using the IBM or TI RAMDACs only. ] Series
PCI
S3 Vision 968
v
v
v
v
v
v
v
v
v
Stealth Pro
ISA
S3 928
v
v
v
v
Stealth SE
PCI
S3 Trio32
v
v
v
ELSA
Victory 3D
PCI
S3 ViRGE (86C325)
v
v
v
v
v
v
Winner 1000
VLB
S3 928
v
v
v
Winner 1000 AVI
PCI
S3 Vision 868
v
v
v
v
v
Winner 2000
VLB
S3 928
v
v
v
v
Winner 1000Pro-VL [The ELSA Winner 1000Pro with the ATT20C498 RAMDAC is supported. ]
VLB
S3 Vision 864
v
v
v
v
v
Winner 2000Pro-PCI
PCI
S3 Vision 964
v
v
v
v
v
v
v
v
Winner 2000Pro-VL
VLB
S3 Vision 964
v
v
v
v
v
v
v
v
Winner 2000Pro-X
PCI
S3 Vision 968
v
v
v
v
v
v
v
v
v
Winner 3000-S
PCI
S3 ViRGE (86C325)
v
v
v
v
v
Everex
FIC 864P
PCI
S3 Vision 864
v
v
v
v
v
VGA Trio 64P
PCI
S3 Trio64
v
v
v
v
v
ViewPoint 64P
PCI
S3 Vision 864
v
v
v
v
v
Genoa
SuperVGA 7000
v
Hercules
Dynamite 128/Video
PCI
Tseng ET6000
v
v
v
v
v
v
Hewlett-Packard
HP NetServer LC/LE/LF
TVGA 9000i
v
HP Vectra VL2
Cirrus Logic GD5428
v
v
HP Vectra XM2i
S3 Vision 864
v
v
v
HP Vectra XU [Both the STG1702 and the ATT21C498 RAMDACs are supported.]
S3 Vision 864
v
v
v
v
v
IBM
Easy Options (VC550) [Select "Cirrus Logic 542x" when configuring the display adapter during Solaris installation.]
ISA
Cirrus Logic GD5428
v
PC 330--Model 6575
S3 Vision 864
v
v
v
v
v
PC 330--Model 6576
S3 Trio64
v
v
v
PC 350--Model 6581
Cirrus Logic GD5430
v
v
v
v
PC 360--Model 6598
MGA Storm
v
v
v
v
v
v
v
v
PC 750--Model 6885-35H
S3 Vision 864
v
v
v
v
v
PC 750--Model 6885-J0M
S3 Vision 864
v
v
v
v
v
PC Series 300-486
Cirrus Logic GD5430
v
v
PC Series 300
S3 Vision 864
v
v
v
v
v
PC Series 700
S3 Vision 864
v
v
v
v
v
PC Server 310--Model 8639-0DT
S3 Vision 868
v
v
v
v
PC Server 310--Model 8639-0EO
S3 Trio64V+
v
v
v
PC Server 310--Model 8639-0XT
S3 Vision 864
v
v
v
PC Server 320--Model 8640-0DV
Cirrus Logic GD5428
v
v
PC Server 320--Model 8640-0NJ
Cirrus Logic GD5428
v
v
PC Server 320--Model 8640-0XT
Cirrus Logic GD5428
v
v
PC Server 320--Model 8640-0YT
Cirrus Logic GD5428
v
v
PC Server 320--Model 8640-MXT
Cirrus Logic GD5430
v
v
PC Server 325--Model 8639-ESO
Cirrus Logic GD5436
v
v
v
PC Server 325--Model 8639-ESV
Cirrus Logic GD5436
v
v
v
PC Server 500--Model 8641-0YR
Cirrus Logic GD5428
v
v
PC Server 500--Model 8641-0YT
Cirrus Logic GD5428
v
v
PC Server 520--Model 8641-ED2
Cirrus Logic GD5428
v
v
PC Server 520--Model 8641-EDG
Cirrus Logic GD5428
v
v
PC Server 520--Model 8641-EZS
Cirrus Logic GD5428
v
v
PC Server 520--Model 8641-EZV
Cirrus Logic GD5428
v
v
PC Server 720--Model 8642-0ZO
Cirrus Logic GD5428
v
v
PS/ValuePoint
S3 805
v
PS/ValuePoint Performance Series
S3 Vision 864
v
v
v
v
v
VGA [640x480, 16 colors. Any 256-Kbyte or better VGA adapter supporting standard IBM mode 0x12 graphics. For VGA with 800x600 virtual screen, select "16 color, 640x480 VGA panning @800x600 (for experts only, see docs)" when configuring the display adapter during Solaris installation. Warning: This selection enables panning mode on a standard VGA. This video mode supports a virtual resolution of 800x600, but is only capable of physically displaying 640x480 pixels at a time. This may be a preferred mode to use on small screens, but the use of panning may require some training.]
ISA
IBM VGA
v
Intel
Professional/GX High Resolution
ATI Mach32
v
v
v
v
TMI/IPG
WD9031A
v
Xpress VGA
WD90C31
v
Intergraph
TD-1 [To support 1152x900 or 1280x1024 resolution on the Intergraph TD-1 display adapter, you must select an interlaced monitor type when configuring the Solaris window system. Choose "Multifrequency 56kHz (up to 1280x1024 interlaced)" as the monitor type.]
S3 928
v
v
v
v
G95 [To support the Intergraph G95, select the graphics card "Matrox MGA Millennium" when configuring the Solaris window system.]
PCI
MGA Storm
v
v
v
v
v
v
v
v
v
v
ISMP (SMP 224) [To support the Intergraph ISMP, select the graphics card "Cirrus Logic GD5434" when configuring the Solaris window system.]
Cirrus Logic GD5434
v
v
v
v
v
v
Matrox
Millennium
PCI
MGA Storm-R1
v
v
v
v
v
v
v
v
v
v
Millennium 220
PCI
MGA Storm-R2
v
v
v
v
v
v
v
v
v
v
Millennium 220
PCI
MGA-2064-R2
v
v
v
v
v
v
v
v
v
v
Millennium 220
PCI
MGA-2064W-R3
v
v
v
v
v
v
v
v
v
v
Millennium II
PCI, AGP
MGA-2164W
v
v
v
v
v
v
v
v
v
v
Millennium G200
AGP
MGA-G200
v
v
v
v
v
v
v
v
v
v
Millennium G400
AGP
MGA-G400
v
v
v
v
v
v
v
v
v
v
Mystique
PCI
MGA-1064SG
v
v
v
v
v
v
v
v
v
Mystique 220
PCI
MGA-1064SG (-G or -H) (or MGA-1164SG)
v
v
v
v
v
v
v
v
v
Mystique G200
AGP
MGA-G200
v
v
v
v
v
v
v
v
v
v
Mystique G400
AGP
MGA-G400
v
v
v
v
v
v
v
v
v
v
Productiva G100
PCI, AGP
MGA-G100
v
v
v
v
v
v
v
v
v
v
Micronics
Mpower 4 plus
ATI Mach64
v
v
Miro
miroCRYSTAL 20SD
PCI
S3 Vision 864
v
v
v
v
v
miroCRYSTAL 40SV
PCI
S3 Vision 964
v
v
v
v
v
v
v
Nanao
EizoAccel AA51
ISA
F82C480
v
v
Nanao HA50/HL50
ISA
S3 928
v
v
v
Nanao HA60
ISA
S3 928
v
v
v
Number Nine
#9GXE [The Number Nine #9GXE video display adapters (ISA and VESA local bus) support 24-bit color in 640x480 mode only.]
ISA
S3 928
v
v
v
v
#9GXE
VLB
S3 928
v
v
v
v
#9GXE64
PCI
S3 Vision 864
v
v
v
v
v
v
#9GXE64 Pro
PCI
S3 Vision 964
v
v
v
v
v
v
v
v
9FX Motion 331
PCI
S3 Trio64V+
v
v
v
v
v
9FX Motion 531
PCI
S3 Vision 868
v
v
v
v
9FX Motion 771
PCI
S3 Vision 968
v
v
v
v
v
v
v
v
v
9FX Reality 332
PCI
S3 ViRGE (86C325)
v
v
v
v
v
9FX Reality 334
PCI
S3 ViRGE/GX2 (86C357)
v
v
v
v
v
v
v
Imagine 128
PCI
Imagine 128
v
v
v
v
v
v
v
v
Imagine 128 Pro
PCI
Imagine 128
v
v
v
v
v
v
v
v
v
v
Imagine 128 Series 2
PCI
Imagine 128 V2
v
v
v
v
v
v
v
v
Imagine 128 Series 2e [The 8-Mbyte version of the Number Nine Imagine 128 Series 2e is not supported.]
PCI
Imagine 128 V2
v
v
v
v
v
v
v
Vision330 [Select "#9GXE 64 (Trio64)" when configuring the display adapter during Solaris installation.]
PCI
S3 Trio64
v
v
v
v
v
Oak Technology
OTI107
PCI
OTI107
v
v
v
v
v
OTI111
PCI
OTI111
v
v
v
v
v
Orchid
Kelvin 64
PCI
Cirrus Logic GD5434
v
v
v
v
v
Kelvin 64 [Older versions of the Orchid Kelvin 64 VLB card have memory addressing limitations that may cause problems on systems containing 32 Mbytes or more of RAM. If you experience a problem, contact Orchid Technology for assistance.]
VLB
Cirrus Logic GD5434
v
v
v
v
v
S3
928
S3 938
v
v
v
v
Trio3D
PCI, AGP
S3 Trio3D (86E366)
v
v
v
v
v
v
v
Trio32
S3 Trio32
v
v
Trio64
S3 Trio64
v
v
v
v
v
Trio64V+
S3 Trio64V+
v
v
v
v
v
Trio64V2/DX
S3 Trio64V2/DX (86C755)
v
v
v
v
v
ViRGE
S3 ViRGE (86C325)
v
v
v
v
v
v
ViRGE/DX
PCI
v
v
v
v
v
v
ViRGE/GX
PCI
S3 ViRGE/GX (86C385)
v
v
v
v
v
v
v
ViRGE/GX2
PCI
v
v
v
v
v
v
v
ViRGE/VX
v
v
v
v
v
v
v
v
v
Vision 864
S3 Vision 864
v
v
v
v
v
Vision 868
S3 Vision 868
v
v
v
v
SPEA
V7-Mercury
ISA
v
V7-Mirage P-64
PCI
S3 Vision 868
v
v
v
v
v
STB
Lightspeed 128
PCI
Tseng ET6000
v
v
v
v
v
Lightspeed VL
VLB
Tseng ET4000/W32p
v
v
v
v
v
Nitro 3D
PCI
v
v
v
v
v
v
v
Nitro 64 Video
PCI
Cirrus Logic GD5446
v
v
v
v
v
Nitro PCI
PCI
Cirrus Logic GD5434
v
v
v
v
v
v
PowerGraph 64
PCI
S3 Trio64
v
v
v
v
v
PowerGraph 64 3D
PCI
S3 ViRGE (86C325)
v
v
v
v
v
v
PowerGraph 64 Video
PCI
S3 Trio64V+
v
v
v
v
v
PowerGraph ERGO
ISA
Tseng ET4000
v
PowerGraph PRO PCI
PCI
S3 Vision 864
v
v
v
v
v
Velocity 3D
PCI
v
v
v
v
v
v
v
v
v
Velocity 64V
PCI
S3 Vision 968
v
v
v
v
v
v
v
v
Toshiba
J3100
Western Digital 90C31A
v
v
Trident
9440 [This card does not work at the 1024x768 resolution with a 56-kHz refresh rate.]
PCI
TGUI9440
v
v
9680
PCI
TGUI9680
v
v
v
v
9685
PCI
TGUI9685
v
v
v
v
Tseng
Tseng ET6000
Tseng ET6000
v
v
v
v
v
Western Digital
Paradise Accelerator
ISA
WD90C31
v
