Sun Cluster Data Service for DHCP Guide for Solaris OS explains how to install and configure SunTM Cluster HA for DHCP on both SPARC® and x86 based systems.
In this document, the term “x86” refers to the Intel 32-bit family of microprocessor chips and compatible microprocessor chips made by AMD.
This document is intended for system administrators with extensive knowledge of Sun software and hardware. Do not use this document as a planning or presales guide. Before reading this document, you should have already determined your system requirements and purchased the appropriate equipment and software.
The instructions in this document assume knowledge of the SolarisTM Operating System and expertise with the volume manager software that is used with Sun Cluster.
Sun Cluster software runs on two platforms, SPARC and x86. The information in this document pertains to both platforms unless otherwise specified in a special chapter, section, note, bulleted item, figure, table, or example.
This document contains information about commands that are specific to installing and configuring Sun Cluster data services. The document does not contain comprehensive information about basic UNIX® commands and procedures, such as shutting down the system, booting the system, and configuring devices. Information about basic UNIX commands and procedures is available from the following sources:
Online documentation for the Solaris Operating System
Solaris Operating System man pages
Other software documentation that you received with your system
The following table describes the typographic changes that are used in this book.
Table P–1 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 |
The names of commands, files, and directories, and onscreen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 |
What you type, contrasted with onscreen computer output |
machine_name% su Password: |
AaBbCc123 |
Command-line placeholder: replace with a real name or value |
The command to remove a file is rm filename. |
AaBbCc123 |
Book titles, new terms, and terms to be emphasized |
Read Chapter 6 in the User's Guide. Perform a patch analysis. Do not save the file. [Note that some emphasized items appear bold online.] |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
C shell prompt |
machine_name% |
C shell superuser prompt |
machine_name# |
Bourne shell and Korn shell prompt |
Bourne shell and Korn shell superuser prompt |
Information about related Sun Cluster topics is available in the documentation that is listed in the following table. All Sun Cluster documentation is available at http://docs.sun.com.
Topic |
Documentation |
Data service administration |
Sun Cluster Data Services Planning and Administration Guide for Solaris OS |
Individual data service guides |
Concepts | |
Overview | |
Software installation | |
System administration | |
Hardware administration |
Sun Cluster 3.0-3.1 Hardware Administration Manual for Solaris OS |
Individual hardware administration guides |
Data service development | |
Error messages | |
Command and function reference |
For a complete list of Sun Cluster documentation, see the release notes for your release of Sun Cluster at http://docs.sun.com.
Third-party URLs that are referenced in this document provide additional related information.
Sun is not responsible for the availability of third-party web sites mentioned in this document. Sun does not endorse and is not responsible or liable for any content, advertising, products, or other materials that are available on or through such sites or resources. Sun will not be responsible or liable for any actual or alleged damage or loss caused or alleged to be caused by or in connection with use of or reliance on any such content, goods, or services that are available on or through such sites or resources.
Sun Function |
URL |
Description |
Documentation |
Download PDF and HTML documents, and order printed documents |
Support and Training |
Obtain technical support, download patches, and learn about Sun courses |
Sun Microsystems offers training in many Sun technologies through a variety of instructor-led courses and self-paced courses. For information about the training courses that Sun offers and to enroll in a class, visit Sun Microsystems Training at http://training.sun.com/.
If you have problems installing or using Sun Cluster, contact your service provider and provide the following information:
Your name and email address (if available)
Your company name, address, and phone number
The model and serial numbers of your systems
The release number of the Solaris Operating System (for example, Solaris 8)
The release number of Sun Cluster (for example, Sun Cluster 3.0)
Use the following commands to gather information about each node on your system for your service provider.
Command |
Function |
Displays the size of the system memory and reports information about peripheral devices |
Displays information about processors |
Reports which patches are installed |
Displays system diagnostic information |
Displays Sun Cluster release and package version information |
Also have available the contents of the /var/adm/messages file.
