Name | Description | Attributes | See Also
Syntax |
duration |
Default value |
3600 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum length of time a client connection can remain idle before being closed.
The duration is expressed in seconds.
This property is used to configure the following features:
The LDAP listener represents the network interface of Directory Proxy Server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
