Name | Synopsis | Description | SYNTAX | Usage | Attributes
( 1.3.6.1.4.1.42.2.27.9.1.791 NAME 'dsSaslMaxBufSize' DESC 'Sun DS attribute for SASL config' SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE X-DS-USE 'internal' X-ORIGIN 'Sun Directory Server' )
Reflects the maximum buffer size for SASL, which limits the size of packets accepted from SASL clients. The default value is 65535, and is not modifiable. The actual value used is negotiated to be less than or equal to this maximum.
Integer, single-valued.
Attribute specific to this Directory Server instance and version of the schema.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
