Name | Description | Attributes | See Also
Syntax |
duration |
Default value |
5000 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum length of time that the availability monitor waits to establish a connection to the LDAP data source.
The duration is expressed in milliseconds.
The value of this property must be at least 1.
This property is used to configure the following features:
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
