Name | Description | Attributes | See Also
Syntax |
duration |
Default value |
120 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
The availability monitor polls inactive connections to keep them alive. This property specifies how long a connection can be inactive before the availability monitor performs a search on the idle connection to keep it alive.
The duration is expressed in seconds.
The value of this property must be at least 1.
This property is used to configure the following features:
A JDBC data source is defined for each relational database to which you want LDAP clients to have access. Currently, only one JDBC data source is supported per JDBC data view.
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
