Name | Description | Attributes | See Also
Syntax |
duration |
Default value |
30 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the polling interval. When a connection is up, respectively down, the availability monitor polls the connection at this interval to detect its possible failure, respectively recovery.
The duration is expressed in seconds.
The value of this property must be at least 1.
The value of this property cannot be unlimited.
This property is used to configure the following features:
A JDBC data source is defined for each relational database to which you want LDAP clients to have access. Currently, only one JDBC data source is supported per JDBC data view.
The common name of the LDAP data source
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
