Name | Description | Attributes | See Also
Syntax |
string |
Default value |
VARCHAR |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property defines the syntax used to construct an entry in the relational database table from an LDAP entry.
This property is used to configure the following features:
JDBC attributes map LDAP attributes to entries in relational database tables. The definition of a JDBC attribute includes the name of the LDAP attribute, and the relational database table and column in which the corresponding information is located.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWdsee7 |
Stability Level |
Evolving |
dpconf(1M)
