| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster Data Service for Sun Java System Application Server EE (HADB) Guide |
Oracle Solaris Cluster HA for Sun Java System Application Server EE (HADB) Overview
Highly Available HADB Management Agent
Configuration Restrictions and Requirements
Configuration Planning Considerations
Installing and Configuring the Sun Java System Application Server EE (HADB) Software
Creating a Sun Java System Application Server EE (HADB) Management Domain
Installing the Oracle Solaris Cluster HA for Sun Java System Application Server EE (HADB) Packages
The fault monitor for Oracle Solaris Cluster HA for Sun Java System Application Server EE (HADB) is contained in the resource that represents Sun Java System Application Server EE (HADB). You create this resource when you register and configure Oracle Solaris Cluster HA for Sun Java System Application Server EE (HADB). For more information, see Registering and Configuring the Oracle Solaris Cluster HA for Sun Java System Application Server EE (HADB).
System properties and extension properties of this resource control the behavior of the fault monitor. The default values of these properties determine the preset behavior of the fault monitor. The preset behavior should be suitable for most Oracle Solaris Cluster installations. Therefore, you should tune the fault monitor only if you need to modify this preset behavior.
For more information, see the following sections.
Appendix A, Properties for Oracle Solaris Cluster HA for Sun Java System Application Server EE (Supporting HADB Versions as of 4.4) in this guide for a detailed description of the extension properties for the SUNW.hadb_ma resource type
