| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster 3.3 With Fibre Channel JBOD Storage Device Manual SPARC Platform Edition |
Figure A-1 shows a sample storage array configuration.
Note - You must use FC switches when you install storage arrays in a partner-group configuration. If you want to create a storage area network (SAN) by using two FC switches and Sun SAN software, see SAN Solutions in an Oracle Solaris Cluster Environment in Oracle Solaris Cluster 3.3 Hardware Administration Manual for more information.
Figure A-1 Installing a Sun StorEdge A5x00 Storage Array in a Full-Loop Configuration
For more information about how to cable and configure storage arrays, see the Sun StorEdge A5000 Installation and Service Manual.
Figure A-2 shows a sample storage array configuration.
Note - You must use FC switches when installing storage arrays in a partner-group configuration. If you want to create a storage area network (SAN) by using two FC switches and Sun SAN software, see SAN Solutions in an Oracle Solaris Cluster Environment in Oracle Solaris Cluster 3.3 Hardware Administration Manual for more information.
Figure A-2 Adding a Sun StorEdge A5x00 Storage Array in a Full-Loop Configuration
For more information about how to cable and configure storage arrays, see the Sun StorEdge A5000 Configuration Guide and the Sun StorEdge A5000 Configuration Guide.
