The /etc/saf/pmtab/_pmtab file, such as /etc/saf/zsmon/_pmtab, looks similar to the following:
# VERSION=1 ttya:u:root:reserved:reserved:reserved:/dev/term/a:I::/usr/bin/login::9600: ldterm,ttcompat:ttya login\: ::tvi925:y:# |
# VERSION=1 |
Indicates the Service Access Facility version number. |
ttya |
Indicates the service tag. |
x,u |
Identifies whether the following flags are set: x, which means do not enable the service. u, which means create a utmpx entry for the service. |
root |
Indicates the identity assigned to the service tag. |
reserved |
This field is reserved. |
reserved |
reserved |
/dev/term/a |
Indicates the TTY port pathname. |
/usr/bin/login |
Identifies the full pathname of the service to be invoked when a connection is received. |
:c,b,h,I,r: |
Indicates whether the following flags are set: c, sets the connect on carrier flag for the port b, sets the port as bidirectional, allowing both incoming and outgoing traffic h, suppresses an automatic hangup immediately after an incoming call is received I, initializes the port r, forces ttymon to wait until it receives a character from the port before it prints the login: message. |
9600 |
Identifies the TTY label defined in /etc/ttydefs file. |
ldterm,ttcompat |
Identifies the STREAMS modules to be pushed. |
ttya login\: |
Identifies the prompt to be displayed. |
:y/n: |
message |
Identifies any inactive (disabled) response message. |
tvi925 |
Identifies the terminal type. |
y |
Indicates whether software carrier is set (y/n). |
