SAF uses configuration files which can be modified by using the sacadm and pmadm commands. You should not need to edit them manually.
File Name |
Description |
/etc/saf/_sysconfig |
Per-system configuration script. |
/etc/saf/_sactab |
SAC's administrative file that contains configuration data for the port monitors that the SAC controls. |
/etc/saf/pmtag |
Home directory for port monitor pmtag. |
/etc/saf/pmtag/_config |
Per-port monitor configuration script for port monitor pmtag if it exists. |
/etc/saf/pmtag/_pmtab |
Port monitor pmtag's administrative file that contains port monitor-specific configuration data for the services pmtag provides. |
/etc/saf/pmtag/svctag |
Per-service configuration script for service svctag. |
/var/saf/log |
SAC's log file. |
/var/saf/pmtag |
Directory for files created by pmtag, for example, log files. |
